Thread: Newbie CNC Build
21-03-2012 #27
Well think about it Just about every CNC machine even those costing 10's thousands of pounds are bolted together in some form or another. . . . They are not welded in one piece.!!
The bolted sections will hold up fine so long as you use correct size and good quality bolts and tighten them correctly. If you want to ensure they don't move then use locking/locateing pins.!!. . but they don't move if good quality bolts with locking washers with a bit of thread lock for good measure.!
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM -
NEW MEMBER: Hi, from a newbie #2
By colonelrichard in forum New Member IntroductionsReplies: 2Last Post: 04-08-2009, 03:02 AM -
By derekm in forum New Member IntroductionsReplies: 2Last Post: 03-08-2009, 06:45 PM
