Thread: Newbie CNC Build
21-03-2012 #28
Jazz is right on this very much so. My table is totally welded and it turned out fine? well not true, even with all the care in the world the bed still needed a lot taken off the surface to get a straight bed. In most cases that is fine but if i had used bolts i could have adjusted a lot of that out before surfacing. Just to add a bit more to the design try and include adjustable feet, can make a world of different to noise as well as helping adjust to unleveled floors. It aso makes it much easier if you ever needed to move it as well.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM -
NEW MEMBER: Hi, from a newbie #2
By colonelrichard in forum New Member IntroductionsReplies: 2Last Post: 04-08-2009, 03:02 AM -
By derekm in forum New Member IntroductionsReplies: 2Last Post: 03-08-2009, 06:45 PM
