Many thanks - I hadn't considered the potential flexibility offered by interchangeable gearing.
That raises the question: What brand/source of pulleys/belts are currently in fashion/recommended?
{Presumably, belt manufacturers/suppliers provide tensioning guidance?}
Karl
22-03-2012 #2
22-03-2012 #3
22-03-2012 #4
Yes it's all about teeth in mesh.!! With small pulleys there are less teeth engaged between belt and pulley, less teeth engaged means less able to handle high loads and reduce the amount of torque that can be transmitted and if wrong will rip teeth off the belt.
Read these and it will explain lots. . http://www.roymech.co.uk/Useful_Tables/Drive/Timing_belts.html
http://www.ondrives.com/data/pdf/pul...belts-tech.pdf
Centec 2 ballscrews
By jonnydeen in forum Lead Screws, Nuts & SupportsReplies: 29Last Post: 11-07-2023, 09:53 AM -
Bended ballscrews. What i can do?
By ba99297 in forum Lead Screws, Nuts & SupportsReplies: 25Last Post: 13-04-2017, 01:41 PM -
Best place to get ballscrews?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 15-04-2013, 10:09 PM -
pictures of ballscrews??
By wilfy in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 28-10-2012, 09:09 PM -
FOR SALE: RM1610 ballscrews(used + 1605 x 900mm screw (new)
By rbs in forum Items For SaleReplies: 1Last Post: 10-05-2012, 08:23 PM
