  1. Quote Originally Posted by JAZZCNC View Post
    ... HTD 5mm pitch 15mm width and a good brand is Gates, medway etc...
    Many thanks. Are more pulley teeth better than less? Eg for a gearing ratio of, say, 1:2 is there anything to be gained from using 12:24 teeth pulleys as opposed to 20:40 teeth?
    Karl
    Yes it's all about teeth in mesh.!! With small pulleys there are less teeth engaged between belt and pulley, less teeth engaged means less able to handle high loads and reduce the amount of torque that can be transmitted and if wrong will rip teeth off the belt.
    Read these and it will explain lots. . http://www.roymech.co.uk/Useful_Tables/Drive/Timing_belts.html
    http://www.ondrives.com/data/pdf/pul...belts-tech.pdf
  3. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  1. Centec 2 ballscrews
    By jonnydeen in forum Lead Screws, Nuts & Supports
    Last Post: 11-07-2023, 09:53 AM
  2. Bended ballscrews. What i can do?
    By ba99297 in forum Lead Screws, Nuts & Supports
    Last Post: 13-04-2017, 01:41 PM
  3. Best place to get ballscrews?
    By Ross77 in forum Lead Screws, Nuts & Supports
    Last Post: 15-04-2013, 10:09 PM
  4. pictures of ballscrews??
    By wilfy in forum Lead Screws, Nuts & Supports
    Last Post: 28-10-2012, 09:09 PM
  5. FOR SALE: RM1610 ballscrews(used + 1605 x 900mm screw (new)
    By rbs in forum Items For Sale
    Last Post: 10-05-2012, 08:23 PM
