Jig would not be hard. Use a keyless chuck mounted on a bearing. You could use a belt sander with one of the specialised grinding belts used for wood turning tools so that you would get a flat edge.
Just a thought.
BruceThe more I know, I know, I know the less. (John Owen)
Should i use a engraving cutter for this job?
By mark84 in forum Tool & Tooling TechnologyReplies: 0Last Post: 30-01-2014, 07:58 PM -
Carbide cutters
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 24-01-2014, 10:57 AM -
SWAP: 6mm Carbide CNC Router Bits for 3mm's
By Fivetide in forum Items For SwapReplies: 8Last Post: 04-12-2012, 04:47 PM -
sawing cutter MT3 (need identify what bits one could buy for this tool)
By diy-john in forum Machine DiscussionReplies: 4Last Post: 02-04-2012, 03:40 PM
