Thread: Home switching
14-03-2012 #2
Just wire it as shown in the pdf diagram in post#1.
Then set input pins 11 as "Both Limit and home Z", 12 as "Both Limit and home Y" and 13 as "Both Limit and home X" in the parallel port page of the EMC2-stepconf program.
When the EMC2 (its now called linuxcnc) is in homing mode it will move each axis in turn in its specified homing direction until it trips the limit switch and then slowly back off the switch until it opens again. Be careful to set the direction of home search velocity as negative if your home switches are located at the axis minimum, & make sure your emergency stop is working before you test the homing procedure!
14-03-2012 #3
switching from steppers to servos - STEP / DIR control
By dsc in forum Stepper & Servo MotorsReplies: 6Last Post: 18-06-2014, 12:41 PM -
Driver switching OFF
By manofgresley in forum Artsoft Mach (3 & 4)Replies: 13Last Post: 06-06-2014, 04:57 PM -
FOR SALE: 24v 20 amp ABB switching power supply £90
By gavztheouch in forum Items For SaleReplies: 0Last Post: 07-02-2014, 07:42 PM -
Home is where the part is?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 15-07-2013, 09:58 AM -
Home made CNC for 50 €
By Lee Roberts in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 26-05-2009, 08:12 PM
