  1. #10
    All wiring within the control box now complete with the exception of the relays. Next up soldering the stepper and home switch cabling in to the connector panel that breaks out on the top side of the machine (you can see the panel in laid up against the bed in the photo). After this its onto rewiring all the top side with shielded cabling and installing home switches.
    Also in the photo if check left next to electronics enclosure there's a panel. This will be removed and a door fitted to house the PC.
  1. NEW MEMBER: Thanks to existing members
    By Lloyd in forum New Member Introductions
    Last Post: 05-05-2014, 07:35 AM
  2. Upgrade? Chinese CNC Machine
    By Carlb1058 in forum Machine Discussion
    Last Post: 15-08-2013, 09:04 AM
  3. matching drivers to existing motors
    By 2006Nobull in forum Motor Drivers & Controllers
    Last Post: 17-07-2012, 08:27 PM
  4. Upgrade
    By Dopy in forum General Discussion
    Last Post: 09-11-2011, 01:57 AM
  5. BUILD LOG: Time for mk2 upgrade!
    By routercnc in forum DIY Router Build Logs
    Last Post: 26-02-2011, 11:38 PM
