  1. #7
    Quote Originally Posted by doggydoggen View Post
    Hello
    it is correct the m62x1.5 isn’t correct, the name is M62 but the thread is SAE 20, wierd i know
    i bought a nut from suplier here in sweden for about 1 week ago and they told me this, and i have also checked this for about 5 minuts ago..=), i will come back with e-mail and what company you can buy the nut, one moment..=)
    but it is bastards out there so to be sure, buy i thread checker tool and try the SAE 20 on the spindel threads.
    the SAE 20 is very similar to 1.25 metric threads, so i think that will work to, but it is SAE 20
Name:	Arboga Retention collar as supplied.jpg
ID:	23162Click image for larger version.
    Thanks buddy.
    I actually turned a spindle nut and cut the threads myself on my lathe. Knurled the upper portion to make it easy to fix/remove.
    Turned the washer/collar too.
    Actually an easy job and it works a treat.
    Many thanks for the drawings and if anyone is stuck I’ll turn and thread a nut for you.
    I’m also Well through with building a 240v to 415v phase converter to run it, an interesting project on its own.
  1. CONVERSION: Harrison Mill Conversion
    By m_c in forum Conversion Build Logs
    Last Post: 27-10-2016, 07:15 PM
  2. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  3. NEW MEMBER: Saying hello, about to start a mill conversion.
    By irgonomics in forum New Member Introductions
    Last Post: 28-04-2013, 03:35 PM
  4. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
