Thread: CNC Arboga U2508 Mill Conversion
10-04-2013 #26
Ok that makes sense, deep groove bearings pre-loading a taper which can take axial and radial load. I would have thought an AC at the top would have been better as you still get the speed increase from using ball bearings but not the heat issues with pre-loading deep groove bearings, (as you are forcing them to run on the edge of the race) excessive heat will cause expansion and reduce the pre-load on the bearings and therefore rigidity.
This is the theory so it will be interesting to see if in a hobby environment it is actually a problem. that is what I'm trying to find is the balance between the ideal design and what works in practice.
CONVERSION: Harrison Mill Conversion
By m_c in forum Conversion Build LogsReplies: 18Last Post: 27-10-2016, 07:15 PM -
CONVERSION: Sx3 mill conversion
By dazza in forum Conversion Build LogsReplies: 1Last Post: 29-04-2014, 10:23 AM -
NEW MEMBER: Saying hello, about to start a mill conversion.
By irgonomics in forum New Member IntroductionsReplies: 4Last Post: 28-04-2013, 03:35 PM -
Mill conversion to cnc
By wolsey in forum General DiscussionReplies: 1Last Post: 15-08-2011, 11:07 PM -
Help with drill-Mill conversion
By Ross77 in forum Milling Machines, Builds & ConversionsReplies: 134Last Post: 02-04-2010, 10:25 AM
