Thread: Supported rail or other?
True, but the calculations are based on real-world laws of physics. I'm not saying certain things are impossible, you can always empirically achieve theoretically diffcult things - like milling Aluminum with a Dremel - but how long will those bearings last, how does the accuracy drop off as the runout increases, how hot does it get before the poor thing melts, etc... There's no harm in understanding the limitations and designing around them...
All I was trying to show was that the fact that 30mm end-supported rail isnt as good as 12mm supported rail under a range of common tasks that a router/mill might be designed for - which we already knew empirically. I agree "suck it and see" is a good teacher, but equally if I don't have the personal experience I don't take someone else's word for it verbatim without some level of research into the issue. :D
WANTED: Supported rail. The bigger the better
By r0bsk1 in forum Items WantedReplies: 0Last Post: 08-07-2013, 07:50 PM -
round, supported or profiled rail?
By mocha in forum Rails, Guideways & BearingsReplies: 0Last Post: 26-07-2012, 03:44 PM -
WANTED: 2 x 20/16mm supported round rail
By D-man in forum Items WantedReplies: 4Last Post: 30-10-2011, 11:08 PM -
Profile v Supported Round Rail
By Rogue in forum Rails, Guideways & BearingsReplies: 5Last Post: 15-09-2011, 09:29 PM -
Some thoughts on using supported rail
By Ross77 in forum Rails, Guideways & BearingsReplies: 0Last Post: 29-01-2010, 07:13 PM
