26-03-2012 #11
I see, so the motors drop in torque is not proportional to the increase in RPM? If you get more than double the torque at half the RPM then I can understand the argument for 10mm pitch vs. 5mm.
Jazz, have you tried not using the 1:2 gearing and just spinning the motors faster? If you found the slower motor speed is better then I should just follow your advice and go for 10mm pitch ;)
I'd like to go for rotating ballnuts if Jonathan will be kind enough to make the parts for me, as it would be nice to keep the drive motors within the machine frame, rather than stuck on the end. Also I could use ballscrew without end-machining since it would just be held in a clamp.
I can get 2510 ballscrew from Zapp, so can you make a rotating ballnut assembly for that Jonathan?
questions...questions
By victorismyhero in forum Machine DiscussionReplies: 4Last Post: 16-07-2013, 06:44 PM -
few questions.
By jcb121 in forum General DiscussionReplies: 5Last Post: 03-06-2012, 08:20 PM -
NEW MEMBER: Hi all just a few questions!
By dubchip in forum New Member IntroductionsReplies: 17Last Post: 02-12-2011, 10:47 PM -
By dubchip in forum New Member IntroductionsReplies: 3Last Post: 10-11-2011, 03:40 PM -
New in CNC and I have some questions
By demestav in forum General DiscussionReplies: 0Last Post: 14-09-2011, 12:19 PM
