30-03-2012 #18
The advantage of profiled rails are much tighter bearing tolerences with a smooth action helping to reduce resonance and flex they also last much longer, esp in harsh conditions like a Z axis where it's constantly in the firing line and open to crap from the cutter. They don't really add much more strength than supported round rail if any.!
You can use supported rails just the same as profiled like you have seen me do. Absolutely no difference other than they stick off the Z axis rear plate (which you would call running across X axis, me Y axis) slightly more due to height of supported rail.
questions...questions
By victorismyhero in forum Machine DiscussionReplies: 4Last Post: 16-07-2013, 06:44 PM -
few questions.
By jcb121 in forum General DiscussionReplies: 5Last Post: 03-06-2012, 08:20 PM -
NEW MEMBER: Hi all just a few questions!
By dubchip in forum New Member IntroductionsReplies: 17Last Post: 02-12-2011, 10:47 PM -
By dubchip in forum New Member IntroductionsReplies: 3Last Post: 10-11-2011, 03:40 PM -
New in CNC and I have some questions
By demestav in forum General DiscussionReplies: 0Last Post: 14-09-2011, 12:19 PM
