28-03-2012 #11
Moslty fabrication costs/equipment.
Alu profile just needs cut, bolted together with suitable brackets, and with a bit care you have a pretty accurate machine.
Steel needs cut (more expensive/time consuming to do accurately than cutting alu), joined, be that via welding or drilling and brackets, which both take longer than doing similar with alu profile. If welded, you then have to deal with distortion.
Plus alu profile is also more accurate out the box so to speak, as extrusions are usually accurate within a thou, unlike steel which can vary quite a bit.
I've used alu profile for frames before, and cost wise it is more expensive, but takes less time to assemble, and for what I used it for, resulted in a lighter stiffer frame than using steel. Plus it looks cool ;)
questions...questions
By victorismyhero in forum Machine DiscussionReplies: 4Last Post: 16-07-2013, 06:44 PM -
few questions.
By jcb121 in forum General DiscussionReplies: 5Last Post: 03-06-2012, 08:20 PM -
NEW MEMBER: Hi all just a few questions!
By dubchip in forum New Member IntroductionsReplies: 17Last Post: 02-12-2011, 10:47 PM -
By dubchip in forum New Member IntroductionsReplies: 3Last Post: 10-11-2011, 03:40 PM -
New in CNC and I have some questions
By demestav in forum General DiscussionReplies: 0Last Post: 14-09-2011, 12:19 PM
