29-03-2012 #11
You could use shimming steel to do this, a bench grinder can also be used to take the nut down a little.
Humm are you sure?, the top two holes look as though they would pass through the mounting holes for the SMA unit, the middle two dont look like they would have much material for a thread because of the bore in the unit?
As Jonathan said you may need to jig the nut about to get it concentric to the screw, all sounds a little to "make do" for me when a little creativity is all that is needed. Our right honorable gentleman Jonathan could properly fix you up with some custom mounts for a reasonable price.
Somthing to think about also is machine maintenance in the future, maybe unlikly but what if a ball gets jammed or stuck in the nut and you need to take it apart....smash it out with a hammer ?!?!? Obserred, how dare you
.MeLee
questions...questions
By victorismyhero in forum Machine DiscussionReplies: 4Last Post: 16-07-2013, 06:44 PM -
few questions.
By jcb121 in forum General DiscussionReplies: 5Last Post: 03-06-2012, 08:20 PM -
NEW MEMBER: Hi all just a few questions!
By dubchip in forum New Member IntroductionsReplies: 17Last Post: 02-12-2011, 10:47 PM -
By dubchip in forum New Member IntroductionsReplies: 3Last Post: 10-11-2011, 03:40 PM -
New in CNC and I have some questions
By demestav in forum General DiscussionReplies: 0Last Post: 14-09-2011, 12:19 PM
