Thread: Winner 90 DRIVER PTP PROBLEM
Hi all, would be very gratefull for any help please!!!
Have a bussellato optima 3-axis machine which runs Winner90 through windows 98 operating system (was told it only runs in this?)..
I have now installed the Winner90 on a newer PC...
The PC runs windows 7 but I have a Virtual PC running windows 98 in it...
I have installed all the necessary files for Winner90 on this new PC, all the programs seemed to be installed and running correctly untill I connected the COM PORT which 'talks' to the CNC via PTP1000, I then had an error saying initializaton unsuccessful TRY AGAIN? YES/NO...
I am currently stuck as have no documentation on the install and cant find anything on the internet either!
Please Help!Last edited by Lee Roberts; 29-07-2017 at 08:30 PM. Reason: removed link
22-03-2012 #2
Have you set up a com port in the virtual PC.
It will not connect unless you set the port, I assume your PC has an actual port as laptops now no longer have them.
Peter
22-03-2012 #3
Hi Peter,
Thanks for your reply, I will get my I.T guy to look at this tomorrow...
Yes it has a port, the PC has been purpose built to replace the older model, just a shame Winner90 will not run in windows7...
Always thought the updating would be more of a challenge than it seemed and looks like i'm unfortunately correct :(
05-04-2012 #4
01-06-2012 #5
Hello
I have optima running on winner 90 windows 3.1. I have tryed to explore upgrading computer but have no success. I would appreciate if anyone has found a way would they let me know.
If there are any other questions that anyone has about both Busellato optima and Jet machines i would try to help 10 years experience.
Many thanks
John
13-11-2012 #6
Had success, upgraded to windows xp without too much of a hitch in the end...
Now have remote access to the machine making life much easier!
04-06-2015 #7
22-01-2022 #8
Hi every one.
I can install a copy of the Winner90 and PTP1000 on a computer runing Windows XP.
I already did it for a Busellato S.Master and it's woring well
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Bearing fit problem
By paulus.v in forum Linear & Rotary MotionReplies: 7Last Post: 09-10-2013, 09:54 AM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
NEW MEMBER: New with a threading problem
By GeoffS in forum New Member IntroductionsReplies: 4Last Post: 02-12-2009, 09:23 PM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
