24-03-2012 #2
Had some major progress this afternoon, using a single flute up cut bit (5mm wide).
With spindle at max (18000 rpm we think) we tested cutting through the plywood at 3mm and 5mm depths, then tested speeds from 1200 mm/m upto 5000 mm/m.
All speeds gave good results, however over 2000 mm/m it was fantastic! Beautifully clean finish.
More tests to be done this week, also need to get the spindle issue sorted! Ie the one we paid for!
Will keep you updated!
Thank you.
How-To: Feed Rate Calculation
By Lee Roberts in forum Machine DiscussionReplies: 20Last Post: 25-03-2020, 04:09 PM -
Feed and speed equation
By Bush Flyer in forum Spindles & Drive MotorsReplies: 7Last Post: 18-03-2014, 01:32 AM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Spindle Motor Recommendation.
By cambesol in forum Marketplace DiscussionReplies: 0Last Post: 21-11-2013, 12:15 PM -
Chamfer Feed & Speed - G-Wizard?
By Tenson in forum Computer SoftwareReplies: 4Last Post: 05-02-2013, 07:01 PM
