    No the fuse is on the supply input. Stepper drives are damaged when the motor supply leads are interfered with.
    It's on both sides in the diagram on Arc Euro. Stepper drivers can be damaged if the power wires are suddenly unplugged for similar reasons to doing the same to the motor wires. It's less likely but still possible since interrupting the current causes a high dI/dt which will cause a voltage spike.
    So what happens when the onboard fuse goes or does that behave differently ?
    John S -
    overkill is my theory for future upgrades.. same with the transformer. what would you recomend for overkill..
    also i read it as your stepper is rated at x volts. how is the homebrew psu regulated.. to said volts..
  1. eBay TB6560 Stepper Motor Driver Boards
    By Mad Professor in forum Motor Drivers & Controllers
    Last Post: 22-08-2018, 05:32 PM
  2. Ebay CNC motor kits? Any good?
    By gr8fun in forum Gantry/Router Machines & Building
    Last Post: 01-12-2012, 10:58 PM
  3. eBay TB6560 Stepper Motor Driver Boards
    By irving2008 in forum Motor Drivers & Controllers
    Last Post: 07-04-2010, 04:48 PM
  4. manual for eBay TB6560 Stepper Motor Driver Boards?
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 06-01-2010, 10:37 PM
  5. CNC Kits
    By itbookham in forum Milling Machines, Builds & Conversions
    Last Post: 10-11-2009, 02:56 PM
