Thread: ebay board kits v 542 boards
05-04-2012 #21
Have a read through Section 8.2 of this:
http://sound.westhost.com/xfmr2.htm , you are looking at toroidal transformers, doughnut shaped, so you can be 99% certain that parallel operation is safe but it is well worth the time to quote:
Sections 8.1, 11.3 and 12.1 are also worth a quick once over.The transformer manufacturer's specifications will indicate if parallel operation is permitted. If you are unsure, measure the voltages carefully, and avoid parallel connection if the voltages differ by more than a couple of hundred millivolts. There will always be a difference, and only the manufacturer's winding tolerances can predict what it will be. With toroidal transformers, the windings are often bifilar, meaning that the two windings are wound onto the transformer core simultaneously. The tolerance of such windings is normally very good, and should cause no problems.
This is a must read for anyone playing with mains: http://sound.westhost.com/articles/electrocution.htm
If you're bored then http://sound.westhost.com/xfmr.htm is also worth looking at. In fact bookmark the site for a rainy day, there's lots of info in the Articles part and a lot of good projects too. Rod Elliott, the site owner is knowledgeable and well respected, if you are ever uncertain about anything electrical then it's always worth a visit to see if Rod has any advice.
05-04-2012 #22
so secondry in series on the diagram would be red 70v+ , yellow and black joined. orange -v
sorry here is a good detailed page.. http://www.routoutcnc.com/PowerSupply.pdfLast edited by crossleymarko; 06-04-2012 at 12:20 AM.
06-04-2012 #23
ok so i got it, apparently times your ac voltage by 1.4... right gonna go with it i think.. been looking at maplins,?
off the shelf 225va 2x35 3.2a,39.99. not as good as your link to rapid johnathon, i know but what do ya think.
thanks all
06-04-2012 #24
The proper figure is the square root of 2, which is roughly 1.412, however the rated output voltage of the transformer is with the it under the rated load, so off load the voltage is normally a few percent higher, and you need to allow that mains voltage can drift up and down, so you need to allow some margin for error.
Also check out http://www.airlinktransformers.com/ for transformers.
06-04-2012 #25
thanks what range of va am i looking at. ie 300va 0-35 0-35
06-04-2012 #26
07-04-2012 #27
so would 600va 2x35v cover me for all motor upgrades... dont wanna be spending twice...
why would you use axis a by the way for milling... ?
17-04-2012 #28
add vat to the rapid prices,, doh,,! another tenner mate. 49.50 so with caps etc how much do you acctualy save?
17-04-2012 #29
eBay TB6560 Stepper Motor Driver Boards
By Mad Professor in forum Motor Drivers & ControllersReplies: 127Last Post: 22-08-2018, 05:32 PM -
Ebay CNC motor kits? Any good?
By gr8fun in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 01-12-2012, 10:58 PM -
By irving2008 in forum Motor Drivers & ControllersReplies: 13Last Post: 07-04-2010, 04:48 PM -
manual for eBay TB6560 Stepper Motor Driver Boards?
By Dan Brown in forum Motor Drivers & ControllersReplies: 5Last Post: 06-01-2010, 10:37 PM -
CNC Kits
By itbookham in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 10-11-2009, 02:56 PM
