Thread: wall cnc like the wall saw
25-03-2012 #11
This is an issue even if the machine is flat. All material needs clamping securely to prevent slippage into cutters path, even the waste to a big degree.
If your using a vacuum system on a vertical machine then obviously it will need designing to account for the extra force required to hold in vertical position. This is obviously where they went wrong because they tried to use a vacuum system designed for flat machine in the vertical position which is obviosly going to be comprimised if not masively over rated for flat bed use.!!
In my experience so far other than the actuall intial clamping it's absolutly no different to working flat with mechanical clamping methods. The intial clamping or holding the material while clamping is ever so slightly more awkward but easily got round by the use of a temporey slidding ledge for material to rest against while first clamp goes on after that it's no different.
With the correct sized vacuum bed it would be a doddle.!!
Surely the folding design defeats the purpose of having it vertical as you will stll need the area to lay flat.? . . . Plus it won't be so easy to do and maintain accurate machine setup.!!
WANTED: 150mm dia x 15mm wall Ali pipe
By r0bsk1 in forum Items WantedReplies: 9Last Post: 12-06-2014, 04:19 PM -
wall and floor fixing am I the only one ????????????
By luke11cnc in forum General DiscussionReplies: 15Last Post: 30-12-2011, 11:45 PM -
CNC Wall art from JPG
By BJ- in forum Opportunities Available & SoughtReplies: 0Last Post: 29-01-2010, 03:06 PM
