Thread: 542 Vs Geckodrive boards?
Splitting from another thread hijack...
Beginning to realise should have taken up powerboat racing as a cheaper hobby, is it just me or is CNC like a real ife game of snakes and ladders ;-)
After having eaten second TB6560 driver in less than month, on order from China anyone got another spare they`d be prepared to sell , paypal awaits?
Looking at medium term wedging doors open with these drivers and upgrading to something with longer life than a fire fly....
Remembering Jazzcnc`s wise words about drivers that are too small for the motors, the next set will only be driving the motors on a 3040 so litlle drives will do whilst credit card gets some breathing space, and the meglomaniac plans for larger unit to accomodate a larger machine bubble away in the background.
Choice of upgrade appears to between Chinese 542 drives and at marginally extra cost, Gecko drive 251, the 250 looks more of a pain to mount than the cost saving covers:
http://www.charter-controls.com/inde...b_y=0&offset=5
The advice of the panel would be gratefully recieved.
Thanks!
Adam
26-03-2012 #2
What I'm about to propose may not be suitable for many, but for those with modest requirements & small(ish) machines, I'd say it's a much better alternative to the awful TB6560s.
i have an easy cnc 3 axis board....which is based on Allegro A3977 ICs (quite a decent IC) & it performs well - that said it's not particularly cheap. I recently needed a couple of axises (for a pickup winder), and noticed a bare bones A3977 driver boards can be bought for a good price...
http://www.ebay.co.uk/itm/M100-singl...item35baa0386b (bearing in mind the A3977 itself costs about £6. That seller did me two boards for $32 delivered
Yes, if you're a mach3 user, you'll need a breakout board, but I'd imagine the results with these boards will be far better than a Tb6560 - also, A3977s are far easier obtainable than a 3 week wait from china.
If you've the dosh I'd say just go for any of the the 542 drivers that abound everywhere (eg http://www.ebay.co.uk/itm/H-bridge-C...item4600f68e0f ), but if youre a bit strapped than my proposal above is a decent option.
26-03-2012 #3
I'd go for m542 or m752. Various sources show that the gecko's perform very well, however the 251 only accepts up to 3.5A and 50V, yet costs about 25% more than an m752, or equivalent which accepts 70V and 5.2A. Running the motors on 70V as opposed to 50V is likely to make a greater difference to torque than a better control algorithm (if indeed that is the case) in the gecko, plus both the m542 and m752 are rated for sufficient current to run 3nm motors in bipolar parallel. That makes it nice and future proof as it's very likely you'll use 3nm motors on the next bigger machine.
26-03-2012 #4
Adam
Before you run out and buy sherman tanks to drive what i expect to be adequate motors for your machine. Can you give us the details of your motors and table size, what screws you have etc? It will be better to give you an informed opinion against what you have rather than guessing? It is very easy to get carried away spending lots of money on things that are way over the top.If the nagging gets really bad......Get a bigger shed:naughty:
26-03-2012 #5
Adam has already said it's a CNC3040 machine, so yes m752 drivers would be excessive but since he's planning to make a bigger machine I think it's sensible to get the good drivers now instead of buying something mediocre now and spending more later. Unless of course the next machine is huge and needs something more than an m752 driver.
26-03-2012 #6
I'm currently playing with one of these 3040 machines and the back EMF from my nema34 could run these motors. . :rofl:
To be honest I'm quite surprised how strong these little machines are, Note I didn't say well built.!! Thou the electronics look barbage and the spindle is joke.!!
Epoz and Jonathan are both right really IMO. If you just want to get this machine running well then look at getting the cheapist but stable drives you can.! . . .OR . . . Look to the future like Jonathan suggest's. . . . Me I always look to the future and think spend a little more today and save lots down the line.
Oh and Gecko's rock in my world and the cheap chinese drives can't hold a candle to them. Fry one of them and see if the chinese vendor will replace free of charge.? even if it's your own fault.!!!
26-03-2012 #7
I fried 12 of Marriss's 210's. Only to be told it was my motors, wiring, position of the moon etc.
Even though when it fried one an APC drive I had as a back up [ but was sloooow ] would go straight in and run ?
What really pissed me off was 2 years down the line, after switching to Leadshine's with absolutely no problems, Marriss posted on CNCZone " Does anyone remember the 210's that used to blow up on start up ?"
Oh how we laughed [ NOT ]
Christ knows how many Leadshines I have fitted, got to be in the high hundreds, and so far I'm 3 down, That looks good odds to me.John S -
26-03-2012 #8
Well that was abit careless of you wasn't it John.!! . . . Should have been obvious you dropped crumbs into the pins of the first drive shorting the buggers which sent the moon into reverse so reversed the polarity and fried the rest. .
Yes I know you had your nose bent with these John but in the main you must admit Gecko's service on the whole is top notch and the drives are very good.
26-03-2012 #9Visit Us: www.automationshop.co.uk
27-03-2012 #10
Yes but once CNC4You gets new stock in then his will go up.
Believe me steppers are set for a BIG hike in price so buy now.John S -
FOR SALE: Geckodrive G251
By m_c in forum Items For SaleReplies: 1Last Post: 18-01-2022, 07:07 PM -
RFQ: Geckodrive G540 re-wire/installation
By Phildunk in forum Projects, Jobs & RequestsReplies: 7Last Post: 18-03-2013, 12:03 AM -
breakout boards what are you using
By wilfy in forum General ElectronicsReplies: 6Last Post: 01-12-2012, 12:35 PM -
Geckodrive - The G215 Step and Direction or VCO
By Lee Roberts in forum Motor Drivers & ControllersReplies: 0Last Post: 31-03-2012, 10:42 PM -
PMINMO 297/298 boards
By irving2008 in forum Motor Drivers & ControllersReplies: 7Last Post: 20-08-2009, 09:02 PM
