Page 3 of 5 FirstFirst 12345 LastLast
  1. #21
    surely it would be easier to make a custom parallel cable to correct the pinouts rather than rewrite the code?
  2. The Following User Says Thank You to pavlo For This Useful Post:
  3. #22
    Hello to everybody.
    I have one problem with my USB to PARALLEL Port DIY Interface. It's recognized correct on PC with Win XP but when I connect it to my laptop with Win 7/32 device has not recognized (Unknow device) as well as I connect it to my desktop PC with Win 7/64. Any sugestions?
  4. #23
    hello. can ı use thıs project with match3
  5. #24
    Hello Sir.
    sir im having trouble, which program do i need to use to control the leds? I have 8 LEDS in my project. I know how to control them using 8 PINS of the Parallel port and also using the Assembly language to create sequence of each LEDS/PINS., but what i want is, i want to control them using USB. Is this module that you have created can possibly control the LEDs?
    I need your help sir. :(
    Thanks a lot...
    GodBless.
  6. #25
    Where can i download this beta from this thread?
    http://www.mycncuk.com/forums/showth...ull=1#post1797
    The link of the download is dead.
    Thanks for the help.
  7. #26
    I did not see any connection of 5V and ground connection into the pcb design..
    But in the schematic there is 5V and ground connection,
    Any one please help me...
  8. Quote Originally Posted by lkanta View Post
    see here: bottom two connections on right hand set of connectors.
  9. #28
    Hi
    I need to convert this parallel board to USB but the firmware codes aren't suitable for it. Each pin of the parallel port goes through a Fet directly to the a coil of a motor. It controls 2 unipolar stepper motors. As you say if one needs a diferent firmware you could change it and post it here, I kindly ask you to do so.I attach the board for your reference . Thanks
  10. The Following User Says Thank You to sacra For This Useful Post:
  11. #29
    hello good interface such a query to format or convert to gcode ga
    I use vcarve 6.0 and then convert it from the software but it is frozen or has a special software to convert your answer gcode grasias por peru greetings
  12. #30
    you can customize for Mach3?
  1. What is the function of a parallel port breakout board?
    By hbx in forum Machine Control Software
    Last Post: 12-03-2013, 06:18 PM
  2. Stepper motor drive using mach3 from parallel port
    By hmarwat370 in forum General Electronics
    Last Post: 04-02-2013, 08:55 AM
  3. parallel port address
    By Dan Brown in forum Artsoft Mach (3 & 4)
    Last Post: 07-01-2010, 12:04 PM
  4. Laptop, ie no parallel port?
    By tompsky in forum Laptops & Tablets
    Last Post: 11-11-2008, 07:12 PM
  5. Which USB parallel port emulator is the best
    By bruce_miranda in forum General Electronics
    Last Post: 18-09-2008, 03:38 PM
