06-04-2011 #21
surely it would be easier to make a custom parallel cable to correct the pinouts rather than rewrite the code?
The Following User Says Thank You to pavlo For This Useful Post:
17-04-2011 #22
Hello to everybody.
I have one problem with my USB to PARALLEL Port DIY Interface. It's recognized correct on PC with Win XP but when I connect it to my laptop with Win 7/32 device has not recognized (Unknow device) as well as I connect it to my desktop PC with Win 7/64. Any sugestions?
18-09-2011 #23
hello. can ı use thıs project with match3
25-01-2012 #24
Hello Sir.
sir im having trouble, which program do i need to use to control the leds? I have 8 LEDS in my project. I know how to control them using 8 PINS of the Parallel port and also using the Assembly language to create sequence of each LEDS/PINS., but what i want is, i want to control them using USB. Is this module that you have created can possibly control the LEDs?
I need your help sir. :(
Thanks a lot...
GodBless.
26-06-2012 #25
Where can i download this beta from this thread?
http://www.mycncuk.com/forums/showth...ull=1#post1797
The link of the download is dead.
Thanks for the help.
07-08-2012 #26
I did not see any connection of 5V and ground connection into the pcb design..
But in the schematic there is 5V and ground connection,
Any one please help me...
07-08-2012 #27
13-03-2013 #28
Hi
I need to convert this parallel board to USB but the firmware codes aren't suitable for it. Each pin of the parallel port goes through a Fet directly to the a coil of a motor. It controls 2 unipolar stepper motors. As you say if one needs a diferent firmware you could change it and post it here, I kindly ask you to do so.I attach the board for your reference . Thanks
The Following User Says Thank You to sacra For This Useful Post:
06-04-2013 #29
hello good interface such a query to format or convert to gcode ga
I use vcarve 6.0 and then convert it from the software but it is frozen or has a special software to convert your answer gcode grasias por peru greetings
17-10-2013 #30
you can customize for Mach3?
What is the function of a parallel port breakout board?
By hbx in forum Machine Control SoftwareReplies: 13Last Post: 12-03-2013, 06:18 PM -
Stepper motor drive using mach3 from parallel port
By hmarwat370 in forum General ElectronicsReplies: 0Last Post: 04-02-2013, 08:55 AM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM -
Laptop, ie no parallel port?
By tompsky in forum Laptops & TabletsReplies: 3Last Post: 11-11-2008, 07:12 PM -
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
