Page 1 of 4 123 ... LastLast
    This question arises in almost every build log on the forum and every time someone explains why they are unsuitable for most CNC Routers. Here are some simulations I have run to prove the point...
    All rails are 20mm diameter with 150mm between bearing block outer faces. The bearings are attached to a 75x160x20mm plate to which the forces are applied.
    Assumptions:
    Rail / box section ends are perfectly rigidly supported - in reality wont be so deflection will be greater than calculated.
    All joints are perfect, modelled as single entity - in reality will get some deflection between joints.
    The following diagrams each have different scales to make the deflection visible throughout.
    Unsupported rail 200N in Z direction to simulate weight of Z-axis:
Name:	SC20 900mm z200N x50N_steel.jpg
    Supported rail 200N in Z direction to simulate weight of Z-axis:
Name:	SBR20 900mm 200N_steel.jpg
    Unsupported rail 200N in Z direction to simulate weight of Z-axisand 50N in parallel to X for cutting force:
Name:	SC20 900mm 200N_steel.jpg
    Supported rail 200N in Z direction to simulate weight of Z-axis and 50N in parallel to X for cutting force:
Name:	SBR20 900mm z200N x50N_steel.jpg
    Max deflection for supported 0.0074mm vs 0.34mm for unsupported... draw your own conclusion.
  2. The Following 3 Users Say Thank You to Jonathan For This Useful Post:
  3. #2
    Bingo! Thanks for that Jonathan
    Bruce
    The more I know, I know, I know the less. (John Owen)
    So by the time you have factored in unsupported rails, rolled ball screws, or Acme screws, off the shelf commercial extrusion, lovejaw couplings, roller skate bearings as thrusts for ballscrews you have the equivalent of a high tensile wet rice krispies box.
    Good job the builders of these machines don't have access to a FEMA program so they can see where they have gone wrong. :rofl:
    John S -
  5. #4
    ecat's Avatar
    Location unknown. Last Activity: 08-02-2014 Has been a member for 9-10 years. Has a total post count of 157. Received thanks 5 times, giving thanks to others 8 times.
    So, for those of us who are colour blind:
    Case 1) Unsupported deflection is about 100 times greater than supported
    Case 2) Unsupported deflection is about 50 times greater than supported
    Nice work J. Ever thought of designing roller-coasters?
  6. #5
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    This thread just got sticky :tup:
    .Me
  7. #6
    I think they would make a good set of handle bars.
  8. #7
    Very pretty but also a very non accurate picture has been painted here. I use 30mm un supported rails on my machine and the accuracy is as good as can be (way more than my needs). The main factor is that it is all bolted to a very sturdy structure. the problem with your assumption here is that the rails sit on something with a solid base. The main problem with machines is the deflection of the bed and not necessarily the rails? if you look at all those nice machines with expensive supported rails or slides, most of them are mounted on aluminium profile that will flex more than the rail. You need to recalculate this to show the defection of the bed for it to stand up? Also what is this for Milling or routing?
    Thats my 2 pence worth
  9. #8
    Quote Originally Posted by 2e0poz View Post
    Very pretty but also a very non accurate picture has been painted here...
    You seem to be under the impression that I'm trying to say that unsupported rails are weak. I'm not, I'm saying they are many times weaker than their supported equivalent. If 30mm unsupported rails give you enough accuracy, then I'm saying you could achieve the same result on a much smaller diameter with support.
    If I'm honest, I've seen so much abysmal design in commercial machines that I simply ignore what 'expensive' machines do. Their objective is to make money not make good machines, and those different objectives result in different designs.
    Yes, there is deflection in the bed, I'm not implying this accounts for all the deflection. My only point here is that the same diameter of rail is tens of times weaker when unsupported, so all other factors being equal, if given a choice between unsupported and supported, you should go for supported.
    An FEA simulation is never 100% accurate, but it's certainly a big improvement on estimation and common sense. I've simulated bed designs too, here's park of one I'm working on:
  10. #9
    Jonathan i make no accusations, i just responded to your weak bold statement that lacked accountability of all facts. It was you that made the statement that unsupported rails are weak not me. I just pointed out some of the missing facts? If you could show how strong supported rails are attached to 40 x 40 profile like a lot of machines are you will see just how weak they are in comparison to your model?
    PS I'm a performance engineer by trade and do a lot of modeling. i would get shot down in flames if i presented statements like that without all the facts.
  11. The Following User Says Thank You to Swarfing For This Useful Post:
  12. #10
    And your point is? They'll still be stronger than the same size of unsupported rail which was the point Jonathan was making.
    Obviously not a great one since your using unsupported rails
    Use some common sense in this thread, realise this isn't a white paper on rail strength and that everyone here is a hobbyist
  1. round rails
    By wilfy in forum Rails, Guideways & Bearings
    Last Post: 01-11-2012, 01:10 AM
  2. Z axis assembly - unsupported rail for very limited movement
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 10-10-2012, 12:44 PM
  3. Limiting unsupported extension on Zaxis.
    By Rogue in forum Gantry/Router Machines & Building
    Last Post: 03-09-2011, 12:30 AM
  4. Unsupported Precision Round Rail Calculator
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 24-08-2010, 06:47 PM
