    Hi All
    I was in need of some small parts cut either cnc or laser cut to construct some small brackets and wondered if anyone here could do it. I have tried local firms but none can be bothered with the small amount I need, and have either said no or quoted me huge amounts of money.
    I just need the nine pieces as shown cut in 4mm mild steel, and have attached both dxf and picture.
    Many thanks
    :) Don
    Attached Files Attached Files
    Hi Don
    Had any luck with this yet? I could get a price from my main profiler if you wanted
    Darren
    Hi m8
    That would be great, as I'm having real hassle finding anyone that wants such a small job.
    Yeah no worries, should be able to get some reasonable prices seeing that I spend over £40k a year on profiled parts....
    For some reason I can't open the dxf file....do you have a fully dimensioned pdf you could send? or a dwg file suitable for opening with autocad 2002
    Have a look at our web site (www.hi-speceng.co.uk) as we offer numerous different services, the latest of which is a wet spray finishing section for the fabrication and products we produce or free issue items if need be
    I've e-mailed some laser cut prices to you - hope they are of interest
  1. RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
    By nobby in forum Projects, Jobs & Requests
    Last Post: 29-04-2014, 12:36 PM
  2. Ball nut brackets, how big do they have to be ?
    By EddyCurrent in forum Lead Screws, Nuts & Supports
    Last Post: 10-03-2014, 03:50 PM
  3. RFQ: 5mm steel plate plasma or laser - can supply sheetcam g-code for mach 3,
    Last Post: 07-03-2014, 07:56 PM
  4. Where to get 1/8" sheet mild steel laser/water jet cut?
    By HankMcSpank in forum Marketplace Discussion
    Last Post: 10-02-2010, 01:28 AM
  5. WANTED: Bridgeport x and y bearing brackets
    By Philmollatt in forum Items Wanted
    Last Post: 10-10-2009, 03:22 AM
