Thread: Homemade CNC Project Help
03-04-2012 #1
Hi, im chris and new to all this so just after a bit of guidance and help, i have decided that i am going to build my own CNC router as i would only be able to afford a cheap small chinese one and this way i can make it how i want and how i need it and also make it bigger for the same price if not cheaper, or so i am led to believe ? i need it to cut, wood, plastics and aluminium and have a working area of around at least 600mmx400mm and need a depth of around 200mm. Is this acheivable ? i am an engineer so have got a basic understanding and shouldnt have a problem constructing it, i just need a bit of guidance as i have limited knowledge of CNC machines. I have a few questions for example with this setup would i be able to make 3D models ? i presume it cuts a layer at a time and just goes over each and over again to get the required model ? On average what would be a realistic budget to set myself ? and what are some good websites for cheap parts ? i look forward to all your replys, thanks
04-04-2012 #2
Yes you should be able to make a much better machine for the same price, or for not much more.
Woods / pastics, easy. How often do you expect to be cutting aluminium and what thicknesses? If you're doing it regularly the machine will need to be significantly stronger than one just for cutting woods and plastics, otherwise it will be very slow when cutting aluminium.
As an engineer do you have access to a milling machine or lathe? If you have got, or know someone, with a milling machine that will make things easier and cut the cost significantly. When I made my machine I already had a small milling machine and mini lathe which meant I only needed to buy the rails/ballscrews/motors - made everything else myself.
Yes certainly. I'm guessing this is why you've opted for 200mm travel on the Z-axis, which is quite large for a machine this size? What is the maximum height of a part you expect to cut? That's height of cutting, not overall height. To be able to cut aluminum you will want to make the bed height adjustable so you can minimise the distance from the tool tip to the gantry when cutting aluminum to reduce tool deflection.
For that size £1500 would make a great machine capable of cutting aluminium. Up to £2000 would be ideal to make a machine that size capable of cutting aluminum efficiently.
BUILD LOG: jon's homemade cnc
By jonbabbz in forum DIY Router Build LogsReplies: 65Last Post: 11-03-2021, 05:13 AM -
FOR SALE: Homemade 'Coventry' Type Easy Change Toolholders
By jamesgates1000 in forum Items For SaleReplies: 8Last Post: 04-12-2015, 09:22 PM -
Homemade 3d laser scanner and free software.. looks really good
By Fivetide in forum Laser Machines & BuildingReplies: 2Last Post: 03-09-2012, 01:09 AM -
BUILD LOG: Few pics of my homemade CNC mill
By wiatroda in forum DIY Router Build LogsReplies: 22Last Post: 18-02-2011, 09:43 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
