    Could be a Clarkson, does it take standard end mills?. Is there a pointed dimple inside the body at the top?.
  2. Quote Originally Posted by fisherjim View Post
    Yes, there's something that looks like a little centre in there.., here are some pics...
ID:	129   Click image for larger version.
ID:	130   Click image for larger version.
ID:	131   Click image for larger version.
    That's the one...
    Screw the nose shut, it doesn't grip until the cutter is in place. Screw in a milling cutter until it hits the pin, open the nose slightly so you can screw the cutter in another quarter turn then tighten the nose.
    Don't screw the cutter in too far, smaller sizes can shatter if not supported by the threads because the nut drives against them.
  4. Quote Originally Posted by Robin Hewitt View Post
    That's the one...
    Hmmm, I dont understand - what does the cutter 'screw' onto, there's no thread as such inside...
    [edit]Ah - I see... its a Clarkson Posilock.. uses threaded tanged collets... so I need to buy a set of collets at £35 then some special threaded endmills at £5 - 8 a go...
    Should I maybe just go get an ER25 or ER32 collet set...?[/edit]
    So you didn't get the wooden box with chuck, spanner and set of four Imperial collets then?
    No great loss, compared to the ER32 I now use, it's a piece of dung. Millling cutters from yesteryear only.
    I tried inserting a bolt in the back of the 1/4" collet to give it something to press against so I could use an unthreaded cutter, but it didn't have the grip.
  6. Quote Originally Posted by Robin Hewitt View Post
    Thats all the argument I need to go buy an ER32 chuck with collet set from RDG or Chronos...
  7. Thinking this through further... my lathe has an MT3 taper also would it make more sense to buy:
    ER32 MT3 Collet set
    or
    MT3 Collet set
    Whats the advantage/disadvantage of the direct acting collets?
  1. Replies: 1
    Last Post: 29-01-2013, 11:05 AM
  2. WANTED: collet chuck
    By Miniman in forum Items Wanted
    Last Post: 13-12-2012, 05:26 PM
  3. FOR SALE: Clarkson Autolock Collet chuck set, Boxed INT 30 / NMTB30 taper
    By swarf-boy in forum Items For Sale
    Last Post: 04-01-2011, 05:28 PM
  4. FOR SALE: INT 30 / NMTB30 Clarkson Autolock Collet chuck set, Boxed
    Last Post: 03-01-2011, 09:53 PM
  5. I'm not self centered chuck
    By GeorgeD in forum Milling Machines, Builds & Conversions
    Last Post: 28-07-2010, 08:20 PM
