    You should be able to attach them to a post using the advanced view. Same method you used for attaching the original pictures.
    My Zip file. It's too big "5.76 MB" ...
    I sent an email with all the zip files, but in the meantime I made changes. Can I send again to your e-mail?
    Hi again.
    I made ​​a few changes in my router project. after taking account of the costs, I came across the need to make some adjustments. My budject is smalest. But what I ask is that comment on the change in the yy axis (the botom linear guide).
    My YY axis is all in alumineo, 20mm thickness, is better than steel tube? probably more expensive... but less heavy.
    I also change the ball-screw diameter and pitch instead 2005 I use 1610. I could control the resolution with pulleys.
    Please comment.
    Thanks.
    Sorry my English ...
    __________________
    Sincerely
    CarloSilva
ID:	5896Click image for larger version.
ID:	5897Click image for larger version.
ID:	5898Click image for larger version.
ID:	5899Click image for larger version.
ID:	5900Click image for larger version.
ID:	5901Click image for larger version.
ID:	5902Click image for larger version.
ID:	5903Click image for larger version.
ID:	5904Click image for larger version.
  1. What is your opinion of the CNC 6040 Router Machine ?
    By John S in forum Chinese Machines
    Last Post: 30-11-2023, 10:58 AM
  2. BUILD LOG: Stell frame cnc 1500X1000. Adjustable table your opinion please
    Last Post: 31-12-2020, 09:53 PM
  3. Best all round mill/router? Vertical mill or gantry router?
  4. Your Opinion MK2 .. STRIKE CNC machine
    Last Post: 25-05-2012, 03:49 AM
  5. Your Opinion
    Last Post: 22-05-2012, 11:02 AM
