Thread: CNC design for consideration
09-04-2012 #2
Hi Jon,
No problem on the double post's, I have taken care of this for you. Not sure if the link to 1500mm x 1000mm is supposed to be there so I have left it.
Good luck with the build, as noted I would consider going with 20mm rails and if you can Ball screws on each axis. 16mm will work as you know but I would too rather see 20mm rails over a 1500mm length, you could always go to 80x80 profile for the Y axis and this would give you the 40mm centre’s the rail would require for mounting, however 80x80 is not cheap I know so...
Preparation for a 4th axis at this stage would be a good idea, people have been known to bolt a 4th axis to the y table as and when they need it.
Regards,
.Me
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
RFQ: Pre-RFQ Design
By Hutchie in forum Projects, Jobs & RequestsReplies: 11Last Post: 05-02-2012, 06:45 PM -
