Thread: parralell port voltage.
when i press the curser keys to try and see voltage should i get a change in the on sceeen coordinates (are the called dro)
as i get nothing in mach 3.
10-04-2012 #2
Yes, when pressing the arrow keys, or pg up/down they should change. If not then it's probably in emergency stop mode. Have you (for now) disabled the emergency stop, or is it flashing? Go to config->ports and pins and look for e-stop, then change it from active high to active low (or vice versa, i.e. invert it). That should get it running...
The Following User Says Thank You to Jonathan For This Useful Post:
11-04-2012 #3
done driver test, system under mach controll
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
Milliamps and voltage help please
By Fivetide in forum General ElectronicsReplies: 13Last Post: 30-09-2012, 01:36 PM -
voltage on motor wires
By phill05 in forum General ElectronicsReplies: 9Last Post: 11-02-2012, 03:43 PM -
Alternator low voltage
By M250cnc in forum General ElectronicsReplies: 12Last Post: 24-02-2011, 11:23 AM -
Bipolar motor voltage
By wildbill in forum General ElectronicsReplies: 10Last Post: 24-02-2010, 12:23 PM
