    Quote Originally Posted by crossleymarko View Post
    no none.. estop is enabled, port 0 pin 0
    Port 0, pin 0 ?????????
    should that be port 1, pin whatever ?
    John S -
    i watched a setup vid on utube.. he had estop enabled, port 0 pin 0.. is this wrong, what would this settin do.
    Yes it should be port 1 and then the pin you assign it to on your bob.
    Like i said before post the XML file and I can load it into Mach here and check it for you. Often it's just a simple setting that like this that stops every thing working.?
  1. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  2. Milliamps and voltage help please
    By Fivetide in forum General Electronics
    Last Post: 30-09-2012, 01:36 PM
  3. voltage on motor wires
    By phill05 in forum General Electronics
    Last Post: 11-02-2012, 03:43 PM
  4. Alternator low voltage
    By M250cnc in forum General Electronics
    Last Post: 24-02-2011, 11:23 AM
  5. Bipolar motor voltage
    By wildbill in forum General Electronics
    Last Post: 24-02-2010, 12:23 PM
