    Do any of you have experience milling carbon fibre pultrusions? I'm thinking about this 10mm box section, and would like to do some mitres and bits. I know it is very stiff, but is it also very hard? Any tips I might need to know? What does it compare to for difficultly in milling; plastics, aluminium, steel?
    Cheers!
    It's immensely abrasive, shags cutters up like no tomorrow, carbide included.
    I think the pro's use diamond coated tooling for it.
    John S -
    Does that make me a pro
    I've cut carbon fibre sheet lots of times. By far the best cutter I found is those cylindrical diamond coated cutters you find in rotary tool kits:
    http://www.ebay.co.uk/sch/i.html?_tr...&_sop=15&_sc=1
    Here's a video of one of these cutting:
    [Ok can't find that, will post when I have]
    E.g:
Name:	DSC09345 (Medium).JPG
ID:	5700Click image for larger version.
Name:	DSC06992 (Medium).JPG
ID:	5701Click image for larger version.
Name:	DSC07002 (Medium).JPG
ID:	5702Click image for larger version.
Name:	DSC07005 (Medium).JPG
    It's a bit slow (300mm/min @24000rpm if I recall correctly), but the cutters last a long time and since it's effectively a grinding process the finish is excellent.
    A chap who does alot with this stuff told me it kills electric spindles very quickly? The 'dust' being very effective at destroying electrical bits....? Anyone had experience of this?
    What sort of spindle is there other than electric? Steam?
    Quote Originally Posted by Tenson View Post
    hehe, I should have said air cooled VS water cooled :)
    The chap thought water cooled would have been much less effected..
    Ahh I see. He probably has a good point, I'll try to avoid letting the dust get about. I'll be using a water-cooled spindle anyway.
  8. Good night:
    To cut carbon fiber with a perfect finish, watch the video.
    Spindle speed 9250 rpm ...
    Feed Rate ..... 920 mm / m
    Rate Plunge ..... 550 mm / m
    Two blade .... End Mill 3 mm
    Carbon Fiber .... Thickness .... 1.5 mm
    http://youtu.be/kYVxcjTuMeg
    Good Works.
    António Pinho
    http://arteemcnc.blogspot.pt/
    Did you find the end-mill became blunt quickly? Was it an uncoated endmill?
  1. FOR SALE: Carbon Fibre Sheet 2mm (all carbon 3k)
    By richie00boy in forum Items For Sale
    Last Post: 27-02-2015, 08:44 PM
  2. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  3. Which of these bits for carbon fiber and fiber glass?
    By craigrobbo in forum Tool & Tooling Technology
    Last Post: 28-02-2013, 01:03 AM
  4. Carbon Fibre Sheet
    By richie00boy in forum Marketplace Discussion
    Last Post: 12-01-2013, 07:46 PM
  5. Carbon fiber keyrings...
    By Jonathan in forum General Discussion
    Last Post: 08-03-2011, 02:39 PM
