Thread: Electrical whizz needed :)
Hi All
Sorry for taking so long to get back, but have been silly busy with work.
Anyway the problem turned out as the guy said to be an internal fuse in the power supply, which was the larger silver box at the back, so they fixed that, but I thought kind of silly of a manufacture to put a fuse internally where it can't easily be reached if it should blow. They also turned the fan around so now it sucks in air via the filter and blows it out the top, but once back working I found my tool height sensor no longer works. Its not the sensor itself on the pendant you push menu then the on/off button and it start a sequence that moves the x axis down to set the tool height but when I hit those buttons nothing happens. The guy so far hasn't got back, but says they are on two separate power systems so wouldn't be connected, but seems very coincidental to me that something blows and something then doesn't work, so will wait and see what he says.
Thanks again for everyones help.
J
Noise, Interference, and unexplained electrical behaviour
By g4ghp in forum General ElectronicsReplies: 4Last Post: 24-04-2014, 11:39 AM -
Excellent info here regarding electrical noise, ideal for panels and machine wiring.
By EddyCurrent in forum General ElectronicsReplies: 0Last Post: 19-10-2013, 12:45 PM -
WANTED: Electrical Box for inverter
By badgerman in forum Items WantedReplies: 1Last Post: 28-09-2013, 11:08 PM -
FREE software for electrical schematics...
By birchy in forum Computer SoftwareReplies: 4Last Post: 15-12-2012, 05:29 PM -
ghost in the x axis - bad electrical connection
By jonm in forum General ElectronicsReplies: 5Last Post: 11-04-2010, 08:31 PM
