14-04-2012 #11
Looking at the specs Oldham couplings tolerate a surprisingly small amount of misalignment, not that that's a reason not to use them since you're doing something wrong if you can't get the shafts close enough...
Timing belts / pulleys are clearly the best solution for driving ballscrews... numerous reasons, but that's not really relevant here.
Hank, if you'd like me to make the part and can send me the drawing by tomorrow morning I should be able to fit it in. I've got plenty of aluminium bar, lots of sizes up to 3.5".
FOR SALE: ArcEuroTrade 650Ncm 14mm Shaft stepper motor
By m_c in forum Items For SaleReplies: 0Last Post: 13-04-2014, 02:19 PM -
misaligned keyway - stepper shaft vs pulley
By dsc in forum Stepper & Servo MotorsReplies: 9Last Post: 25-02-2014, 03:25 PM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
