Clearly the allowable misalignment is inversely proportional to the speed...as you said in the previous post misalignment absorbs power from the motor, in this case through friction. Since steppers are, relatively speaking, such low power motors this is obviously bad, even if the coupling does tolerate it in reality. I'm sure the manufacturers are conservative with the ratings. Hmm, I'm stating the obvious now, tend to make my own anyway.
This is much more interesting:
http://www.youtube.com/watch?v=G2DU1...ture=endscreen
15-04-2012 #2
Help, my "can you ID these couplings thread" has morphed into a fledgling technical debate" :-) (there must be something in the air around these parts?!)
Thanks for all the input...I guess the answer is "no, you can't buy 'em"...so when it comes to it, I'll have to get a better one made than the one I made myself......I'll limp on for now as it does work.
Thanks for the offers....I'll take one of you up on it when I get past my "make do" phase (which - using past history as a precedent - this phase will last far longer than it ought to)
Next question....where do you go to get a heap of 1.6mm thick mild steel in small rectangles made? (something like 4mm x 7mm x 1.6mm) ...I've looked in the local rag, but there's no "Small steel rectangle makers" in there!
Or if you were faced with having to make a few hundred....how would you approach it?Last edited by HankMcSpank; 15-04-2012 at 01:23 PM.
FOR SALE: ArcEuroTrade 650Ncm 14mm Shaft stepper motor
By m_c in forum Items For SaleReplies: 0Last Post: 13-04-2014, 02:19 PM -
misaligned keyway - stepper shaft vs pulley
By dsc in forum Stepper & Servo MotorsReplies: 9Last Post: 25-02-2014, 03:25 PM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
