10-06-2012 #11
11-06-2012 #12
Hi Karl,
For any CNC machine design you just need to ask yourself one question: If I apply the required load to the cutting tool will it deflect less than the accuracy I'm after, or vibrate less than the surface finish I'm after?
If the machine meets those requirements by a reasonable margin then its a good optimal machine. Problem is that although the load requirements are fairly well known (5N wood up to 75N steel as a guide) unless you have access to an FEA programme, and can mesh up the CAD and carry out the analysis, you won't really know how much the tool will deflect under this load. Therefore the advice given in this thread is the arrangement which we believe gives the best performance and lowest risk for those type of bearings. Whilst it might be the case that the bearings on their side arrangement would also give sufficient performance for what you want to do (and I have a feeling it would be), for the same cost the top / bottom arrangement should be superior so it makes sense to use that one.
08-02-2017 #13
Sorry bring up an old thread, but I like the look of this machine, would this design be possible of light aluminium work?
I want to build one similar with the rails rotated.
BUILD LOG: This is my first BUILD please help.
By DigiSoft in forum DIY Router Build LogsReplies: 60Last Post: 27-01-2016, 04:37 PM -
Add-on CNC build log
By bikepete in forum Milling Machines, Builds & ConversionsReplies: 23Last Post: 06-02-2013, 03:02 PM -
Build or buy?
By jonnydeen in forum Machine DiscussionReplies: 6Last Post: 13-05-2012, 11:01 PM -
Just a tip for anyone looking to build CNC
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-07-2010, 06:08 PM -
BUILD LOG: my build
By jonm in forum DIY Router Build LogsReplies: 54Last Post: 22-04-2010, 10:14 PM
