John S,
Yep you are completely correct on that one. CamBam will pocket a "drill" hole where the end mil is smaller in diameter then the required hole and as you can see it does it in a spiral pattern. Works rather well on the code I use and will drill when the endmill is the same diameter as the hole. Rather interesting code structure on that part. As to why it is stopping I don't know as ran fine for me as well. Could be that the OP is getting a false trigger that is causing the problem. Well have fun folks.
Michael
Some Gcode generating programs
By Jonathan in forum Programmers CornerReplies: 20Last Post: 28-02-2014, 07:58 AM -
Help needed for a 3d part gcode for mach3
By Rebekah_harper in forum Computer SoftwareReplies: 33Last Post: 04-11-2013, 01:55 AM -
How to generate Lathe GCode from a drawing?
By Robin2 in forum Computer SoftwareReplies: 18Last Post: 25-10-2013, 04:04 PM -
Tapping Gcode
By Kai in forum General DiscussionReplies: 10Last Post: 14-12-2010, 07:07 PM -
PLease help - gcode newbie
By scotty in forum Programmers CornerReplies: 3Last Post: 07-03-2010, 12:48 PM
