Thread: DIY spindle design
04-12-2008 #10
Small cutters really need much better than a thou TIR. Better than a tenth would be much more suitable. Otherwise the necessary low chip load per tooth will leave you cutting on one flute only. A decent level of precision in the bearings is called for, together with good adjustment for preload. No-name deep grove bearings of unknown class may not get you there. The other killer will be the concentricity of the spindle taper with the bearings seats.
Get these two points right and you are on a winner. Get them wrong an it's going to be a so-so spindle.
Just some thoughts
PHil
PS: I haven't read the whole thread so if I missed something sorry.
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
My spindle design
By Ross77 in forum Tool & Tooling TechnologyReplies: 22Last Post: 06-08-2010, 06:03 PM
