Thread: DIY spindle design
04-12-2008 #10
All good points, Phil, if this were for a precision machine cutting a hard material like steel.
It's going on to a table top router type machine though, intended to cut moulds for composite parts, from mainly EPS foam and MDF. The idea was to make something with a power similar to a small trim router or the larger Dremel type machines, but smaller in diameter, with more robust bearings, a better level of spindle accuracy and, most importantly, a much lower noise level.
If the whole machine turns out to be sufficiently accurate, I may use it for milling/drilling PCBs, although I suspect that the spindle speed will be too low for that task, so I may need to build another, faster, one.
If I get a spindle that is compact, quiet and comparable in accuracy and overall cost to a trim router then it will certainly meet my requirements.
Jeremy
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
My spindle design
By Ross77 in forum Tool & Tooling TechnologyReplies: 22Last Post: 06-08-2010, 06:03 PM
