    Quote Originally Posted by i2i View Post
    if you're parting with the original electronics i would be interested.
    Hi i2i,
    Can you collect from Bradford West Yorkshire ?
    Ta,
    RNR
    i2i's Avatar
    i may be going to the harrogate show sunday, could we sort it out then.
    Could do... Would you come to my place?
    Which bit do you want? I have the original stepper drivers, transformer + big caps, various relays , control panel...
    I kept the spindle driver as it works fine with Mach3.
    What do you think it is worth ?
    Laurent
    i2i's Avatar
    Hi Laurent, the drives, rack, psu +caps and b/recs are all i need, the rest is boxfords own, so too old to be used. I can come to yours either before or after the show. No idea on value, these are more for for spares for old machines.
  5. #15
    OK.... What about 10 quids and a look at my mill ?
    Laurent
  6. #16
    i2i's Avatar
    sounds good to me.
  7. #17
    Cool... Deal!
  8. #18
    Quote Originally Posted by rnr107 View Post
    Hi Ricardoco,
    I'll post the electronic for you... :-) I followed your 260 build and I see you like all these electronic gagets! :-)
    I2I,
    I had a quick look at that ballscrew page, But they seems to have the type of nut I am looking for only in the rolled type of screw...
    Attachment 5819
    Hi there, did you manage to source some new screws for your 260 or did make do with the old, i only ask as my Z spat its balls out and im using a old lead screw as a temporary measure, but will replace all with new machined screws if i can find a reasonable priced source...
    Rick
  9. #19
    i2i's Avatar
    you could machine out the ballnut mounting plate to take a standard flanged nut, and put up with the slight loss of axis movement.
  10. #20
    Hi i2i, if i cannot get some of those threaded ball nuts thats what i will do its not like you would lose much using a conventional nut ...
  1. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  2. The illusive Boxford 260vmc
    By Ricardoco in forum Boxford Vertical Mills
    Last Post: 01-05-2014, 03:26 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
