    Quote Originally Posted by Tenson View Post
    Have a look here where I milled some of the strongest grade of aluminium with the 3040 and 200watt air cooled motor. http://www.mycncuk.com/forums/showth...ll=1#post30109
    It was damn slow, so to be honest the 3040 is not up to it, although I did some softer grade 6mm thick aluminium with reasonable success and at 200mm/min (1mm pass). Given how my 3040 does, I'm reaosnably sure the 6040 with a 1.5KW motor would do pretty well unless you need high speed or very high tolerance.
    What is the softest grade aluminium?
    Hey guys
    Thanks for your input, I managed to view a machine last night from a very nice forum member.
    However with some tweeking we managed to get some reasonbly fast speeds from it.
    PLease note, he had no end mills left so we could unfortunatly only use engraving bits, however given the performance i think an end mill would have been better in this scenario.
    No in the first portion of the video at 2000mm/m it did break (however i am confident a proper endmill wouldn't have broken)
    We dropped the speed down to around 1500mm/m and this munched through quite happily for the next hour or so we played with it.
    One last thing to note was lack of clamping, again down to just using all that was avilable at the time so ther eis a bit of flapping going on.
    ANy way here is the video.
  1. Replies: 112
    Last Post: 07-10-2013, 03:38 PM
  2. My wife has a request
    By luke11cnc in forum Tool & Tooling Technology
    Last Post: 11-12-2011, 02:45 AM
  3. RFQ: ELIC Request - for work to be done.
    By essex_uk in forum Projects, Jobs & Requests
    Last Post: 09-12-2011, 02:52 PM
  4. Intro and request!
    By Imtryin in forum General Discussion
    Last Post: 29-06-2011, 04:27 PM
  5. Please request ugly
    By ali hedi in forum Machine Discussion
    Last Post: 22-09-2010, 11:13 AM
