Thread: 3 Axis CNC router
18-05-2020 #14
I'm with Neale, sounds like Z is trying to move too fast.
I've had to detune my Z quite substantially compared to the X and Y speeds, the rapid upwards Z motions at the start of my cuts caused it to stall. Wonder if its something about moving a heavy spindle directly against gravity - although you'd hope that was only a small factor. It runs approximately 40% of the rapids speeds of X and Y (after correcting for screw pitch differences) and about half the acceleration. Its a 1605 running on a 3.1nm Nema 23, velocity 2m/min, 200mm/s^2 accel. Probably conservative, but works for me. Not a problem in every day life though as the travel is so much smaller :)
Regards the special cable, it requires a slightly custom job. I used a RJ11 crimper and some CAT5 to knock up one - you only use three wires. If you want I'll lend you one.Last edited by AndyUK; 18-05-2020 at 02:00 PM.
There are currently 19 users browsing this thread. (0 members and 19 guests)
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
