Thread: 3 Axis CNC router
	04-05-2012 #1OK, I have introduced my initial ideas on the intros thread and already received some really useful pointers.
 The plan is (after some advice from you guys!) to build an aluminium framed 3 axis 1500x1000mm CNC router driven by 2no. ball screws on the x axis. In order to drive the 2 ball screws on the x axis I intend to use timing belts, linking them to a single stepper motor.
 The ball screws will be either 2005 geared up or 1610. So far I am thinking 2005 because of the potential whip issue over such a large distance.
 Having decided to go down the HTD timing pulleys/belts route for connecting my steppers to the screws I have a few querys I hope someone can shed some light. Please excuse my ignorance! - I'm here to learn.
 My questions are:
 01 which belt width / pitch would you recommend for this application?
 02 I am unsure as to how the pulleys will be attached to the stepper / ball screw - do you have any photographs, technical manuals or just a description of how this can be achieved?
 03 Is the lateral pressure on the screw and motor shaft likely to cause damage to the bearings?
 03 If I mount the steppers through 20mm alu plate will this allow enough length in the motor shaft to connect it to the pulley? if not is there a way of extending the shaft?
 04 in order to adjust/maintain tension on the x-axis drive system I intend to use idler pulleys - how do the bearings work for these pulleys?
 any images people have of successful arrangements would be really useful as I try to move the design of my machine along.
 Thanks in advance!
 Joe
There are currently 176 users browsing this thread. (0 members and 176 guests)
  BUILD LOG: 3 Axis RouterBy GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM
  3-Axis CNC Router - For Helices.By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM
  BUILD LOG: Wobbly: my first 3-axis routerBy Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM
  3 axis cnc/router bedBy dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM
  Need 6' x 4' bed, 4 axis router design.. Help..!By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
