Thread: 3 Axis CNC router
09-02-2017 #331
One of my colleagues sent me this today - figured some of you guys might appreciate it too..!
10-02-2017 #332
Hey Joe,
Sorry for hijacking this thread, but how do you print your schematics that you use to centerpunch your drill holes (your youtube video of Z axis plate for example)
When I try it comes out the wrong size. Tried printing from solid works, exporting to pdf then print and exporting to dxf then print.. nothing seems to work perfect :)
10-02-2017 #333
Ah, guess it depends on your printer? I use the big HP plotter at work which is accurate to a fraction of a mm...
I found the laser printer to be pretty inaccurate maybe because of the heat? What are you printing with?Last edited by JoeHarris; 10-02-2017 at 09:56 PM.
The Following User Says Thank You to JoeHarris For This Useful Post:
11-02-2017 #334
I have only tried the laserprinter at work.. might be the problem :) will try a printshop maybe! Thanks!
11-02-2017 #335
11-02-2017 #336
Yeah :D tried fit to page first.. scratched my head when the print was 22cm instead of 16!
Now I get something like 16.8 :(
11-02-2017 #337
Well there is something wrong as even with a bad printer it should only be about .5mm out.
Can you measure the print exactly and work out the scale and then adjust it.
can you post the dxf up here and I will try and print it for you or adjust it in Acad
Ok edit: I have printed out in SW direct from the part on screen but you have to go into "file/print" and then page setup my printer shows "scale to fit" and "scale "100%" choose 100% It works for me.Last edited by Clive S; 11-02-2017 at 12:30 PM.
11-02-2017 #338
15-02-2017 #339
Hello everyone - bit of progress on the z axis... need to revisit the circuit diagram, the mechanical stuff is getting close now
25-02-2017 #340
Following on from the pictures in the previous post above, another short video of the dry run assembly of the z axis below: https://youtu.be/_0nJBaUaBBA
I still need to make the bracket which fits between the top bearing mount and the z motor mount, the bottom bearing plate and the front z axis plate where the spindle will be mounted.
I'm going to open up the holes on the plates which pull the z bearings forward to allow better alignment. Align them with one another using the dial indicator... the problem is then I cannot get to the bolts which fix the vertical plate to the bearing plate to get that adjusted - wish I had foreseen these problems when designing the thing! Nothing some shims can't fix?!
There are currently 14 users browsing this thread. (0 members and 14 guests)
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
