    Quote Originally Posted by JoeHarris View Post
    It's a new addition because I have a 12v pump but not a big deal - a 24v pump will be cheap enough in the scheme of things! You are right about the VFD switching the pump on so guess being able to switch manually on the mcb will not be all that useful.
    How about this one: https://www.ebay.co.uk/itm/172219861161
    Ah, ok thought was unusual for me to miss something obvious like that.!
    Yep, that pump will be fine.
    Regards the MCB then don't really need MCB but the suitable fuse is required to be safe but only in case of short it's not something you'll use has a switch.
    The VFD Relay will handle this for you and because you'll only ever run the pump when the spindle is spinning you'll have no need to manual overide.
  2. Quote Originally Posted by JAZZCNC View Post
    Thanks Dean - do you tend to screen your alarm signals between drives and IP-M?
  3. The 12V supply has gone!
  4. The Following User Says Thank You to JoeHarris For This Useful Post:
There are currently 14 users browsing this thread. (0 members and 14 guests)
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
