Page 58 of 66 FirstFirst ... 8485657585960 ... LastLast
  1. #571
    Make sure your end mill has flutes long enough. I'm using 6mm bits and the flute length is only 15mm.
  2. #572
    Good point, 25mm is quite long for a small shank bit.
  3. #573
    True. My uncoated carbide 6mm bit also has a 15mm flute but the whole shank is the same diameter so I just go deeper.
  4. #574
    If cutting by hand then use 2 flute spiral upcut which you can get in long flute lengths. Wouldn't use 3 flute by hand as you can't control the speed accuratly enough.
    My preferred choice for Ali is 8mm 3 flute serrated edge roughing cutter followed with 2 flute with full depth finish pass.
    Serrated edge rougher would be good choice for hand routing.
  5. #575
    Thanks for the help all, will follow your tips when the time comes.
  6. Hi Guys. It has been a long old while since I have been on here. I hope you are all keeping well. For one reason or another my CNC build has taken a back seat for a few years but I am hoping to get back to it...
  7. The Following User Says Thank You to JoeHarris For This Useful Post:
  8. #577
    Welcome back Joe :)
  9. #578
    Quote Originally Posted by JoeHarris View Post
    Welcome back Joe
  10. #579
    Welcome back,stay safe!
  11. #580
    Yo Joe nice to have you back..
There are currently 197 users browsing this thread. (0 members and 197 guests)
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
