Thread: 3 Axis CNC router
31-08-2019 #571
Make sure your end mill has flutes long enough. I'm using 6mm bits and the flute length is only 15mm.
31-08-2019 #572
Good point, 25mm is quite long for a small shank bit.
31-08-2019 #573
True. My uncoated carbide 6mm bit also has a 15mm flute but the whole shank is the same diameter so I just go deeper.
01-09-2019 #574
If cutting by hand then use 2 flute spiral upcut which you can get in long flute lengths. Wouldn't use 3 flute by hand as you can't control the speed accuratly enough.
My preferred choice for Ali is 8mm 3 flute serrated edge roughing cutter followed with 2 flute with full depth finish pass.
Serrated edge rougher would be good choice for hand routing.
03-09-2019 #575
Thanks for the help all, will follow your tips when the time comes.
18-04-2020 #576
Hi Guys. It has been a long old while since I have been on here. I hope you are all keeping well. For one reason or another my CNC build has taken a back seat for a few years but I am hoping to get back to it...
The Following User Says Thank You to JoeHarris For This Useful Post:
18-04-2020 #577
Welcome back Joe :)
18-04-2020 #578
19-04-2020 #579
Welcome back,stay safe!
19-04-2020 #580
Yo Joe nice to have you back..
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
