Thread: 3 Axis CNC router
16-06-2020 #651
The motors are soldered to the cy cable and are wired directly to the drives - no connectors! And the cy shields are grounded at a star ground in the cabinet.
But... The frame is not grounded independently come to think of it, should I take a connection from the steel back to star ground? Is that what you mean by chassis?
I will go hunting for loose connections but pretty sure they are all good as I checked last time I had issues...
The last time (previous post) when I stopped the machine after noticing a problem, it carried on doing these movements after both feedhold and stop, it was only the estop cutting power to the motor that stopped it.
16-06-2020 #652
Yes, run a wire from the Star point to the Frame and if you want to take the belt n braces approach then run another to the gantry just in case it's not earthing thru the bearings very well.
Do this before doing anything else. That way you'll see if your problems go away just from this.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
19-06-2020 #653
Well Jazz saves the day again! Amazingly a bit of wire stripped from some twin and earth I had laying around bolted into the frame and back to star ground seems to have done the trick! Ran the machine for 8.5hours continuously without any issues. Cheers Dean
19-06-2020 #654
Here’s what I was making - a topographical map of (part of) the Middle East cut from Ash. 1st 3D work I’ve tried with the machine.
Top left is Antalya in Turkey and the Taurus mountains, then clockwise Cyprus top middle, the Mediterranean coast of Syria and Lebanon, then Israel and Jordan, the Sinai peninsula, Red Sea and finally Suez, and the Nile opening out into the Mediterranean. Pretty pleased with how it turned out.
Took about 10.5 hours total to cut. Roughed with a 10mm straight cutter then finished with a 1mm radius tapered ballnose.
19-06-2020 #655
Nice Job Joe
Great to see it in action.
Regards
Mike
The Following User Says Thank You to mekanik For This Useful Post:
19-06-2020 #656
Please to see your sorted Joe.
Nice job on the 3D work, Can't beat a 3D file to test the build quality and accuracy of a machine, certainly nothing wrong with your machine.
20-06-2020 #657
Little video showing the machine cutting the map for anyone interested in seeing it!
https://youtu.be/xxuR7IvlSUg
20-06-2020 #658
Looking great! It's quite satisfying watching the work appear out of a block, isn't it?
How have you found using the tapered ballnose? I've only got standard ballnose currently, but the tapered look interesting and looks like you can get much longer shaft lengths which is something I've been struggling with.
Also love the Ash; finding a supplier of wood that isn't DIY/Building trade focus is something I'm also struggling with.
21-06-2020 #659
It sure is, hard to leave it alone! The tapered ballnose worked better than I expected. It was a ‘cheap’ Chinese one from SpeTool on Amazon so I wasn’t expecting great things, but couldn’t fault it really. For hardwood, have you tried local sawmills? A couple near me (within 40mins) have offcut sheds with some decent lumps available for quite reasonable prices
The Following User Says Thank You to JoeHarris For This Useful Post:
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
