Thread: 3 Axis CNC router
19-09-2015 #161
first option is quite difficult , my first build i did that ...
second option is way easier, especially if you use epoxy to level.
both my machines are steel welded . i guess using aluminum extruded will be easier for option 1
19-09-2015 #162
The first option is, as Jazz says, like a cornflake packet with the ends removed, just think how stiff that is! If you move the rails nearer the face you'll reduce the flop. I've done this on my gantry and it seems plenty stiff to me. Second option puts the router further out from the face. Both will work...
19-09-2015 #163
19-09-2015 #164
I don't mind the highjack interesting to read... Although I think the cornflake packet is where I'm headed! Jazz when you build your L gantry machines which option do you use? I thought I had seen you use rails top and bottom?
19-09-2015 #165
19-09-2015 #166
Hi Jazz,
So your small design above doesn't have a back piece on the Z axis assembly, but has side panels to give strength to the joints?
Looking again at rail location, would one rail on the bottom and one on the front be a good combination? Like this machine:
19-09-2015 #167
Yes doesn't have back piece because it add's no strength just weight. The Panels you refer to are not for strength, thou they do slightly add some. It's purely a Cover to protect the whole Z axis assembly from dust and crap. It's very affective and neat.
The 90Deg joints are perfectly strong enough for any type of work upto and including machining aluminium.!
Regards rail location then it's a personal choice and also partly machine design related. Me personally I prefer to keep things stout and compact and gain maximum real estate. But if you need clearence for ballscrews etc at the front then putting rails on the front allows this and keeps it stiff. Each way has it's own Plus's & minus's. Both work equally well so take your pick.!!Last edited by JAZZCNC; 19-09-2015 at 11:06 PM.
23-12-2015 #168
23-12-2015 #169
Looking good Joe coming along nicely
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
