Thread: 3 Axis CNC router
01-09-2013 #111
Cheers,
yeah that is just what I want - from what I can see though those bits and pieces are not available as accessories - I can't even find anything on eBay.
Don't see how I could make them without a lathe...
01-09-2013 #112
I'm sure someone with more metal working experience than me will say this won't work but I see 4 parts in that pulley assembly. The pulley, which you would have to buy and the arm which you'd make from three pieces. I reckon you could but bar of the right diameter for the pulley and the machine holes then you just need to fabricate the arm. A scrap of steel, hacksaw and file would probably be enough. Drill and tap the bar and bolt it to the arm, a weld would be better if you have the facilities. Would be an interesting little project.
04-09-2013 #113
Went and had a chat with chap at rotagrip (awesome collection of machines there) and seems my drill speed issue is only going to be solved by buying a better drill! Ah well.
On happier note, feels like this is now becoming a build log rather than a drawing log - pics of progress so far (marking and cutting.)
I am AMAZED by the rage2. 6mm plate and 80x80 box is child's play. Spend most of the evening sweeping up though!!
05-09-2013 #114
I know - i'm amazed by mine as well...i've been chomping through 10mm flat bar without any issues.
What's even more surprising is the quality of cut. I got my steel yard to cut some of my steel to size for me on their large, fluid cooled automatic reciprocating saw thingummy...my cuts are smoother, more accurate & SQUARE in comparison to theirs...lesson learned :-p
05-09-2013 #115
Hi guys
Had a look @ that model, are you cutting steel with the TCT blade or using an abrasive disc ?
05-09-2013 #116
I've actually got the 255mm Rage 3 - just using the stock multipurpose blade that came with it.
I use that blade for most rough jobs & have a decent quality wood blade for more important diy jobs.
I've used it to cut wood, plastic, aluminium & steel - does a decent job on all of them.
There's a video on youtube of a guy in the USA demoing it cutting through loads of different materials & comments on cutting finish & material temperatures etc Its worth a look if you're considering getting one.
The Following User Says Thank You to CraftyGeek For This Useful Post:
10-10-2013 #117
09-11-2013 #118
22-01-2014 #119
24-01-2014 #120
A word of advice to anyone buying a tap wrench - don't buy a cheap eBay jobby like I did - they are crap. Just ordered the real deal from starrett... :) same applies with centre punches - buy a starrett you won't regret it!
There are currently 407 users browsing this thread. (0 members and 407 guests)
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
