Page 12 of 66 FirstFirst ... 210111213142262 ... LastLast
  1. Cheers,
    yeah that is just what I want - from what I can see though those bits and pieces are not available as accessories - I can't even find anything on eBay.
    Don't see how I could make them without a lathe...
  2. #112
    I'm sure someone with more metal working experience than me will say this won't work but I see 4 parts in that pulley assembly. The pulley, which you would have to buy and the arm which you'd make from three pieces. I reckon you could but bar of the right diameter for the pulley and the machine holes then you just need to fabricate the arm. A scrap of steel, hacksaw and file would probably be enough. Drill and tap the bar and bolt it to the arm, a weld would be better if you have the facilities. Would be an interesting little project.
  3. Went and had a chat with chap at rotagrip (awesome collection of machines there) and seems my drill speed issue is only going to be solved by buying a better drill! Ah well.
    On happier note, feels like this is now becoming a build log rather than a drawing log - pics of progress so far (marking and cutting.)
    I am AMAZED by the rage2. 6mm plate and 80x80 box is child's play. Spend most of the evening sweeping up though!!
ID:	9975Click image for larger version.
  4. Quote Originally Posted by JoeHarris View Post
    I know - i'm amazed by mine as well...i've been chomping through 10mm flat bar without any issues.
    What's even more surprising is the quality of cut. I got my steel yard to cut some of my steel to size for me on their large, fluid cooled automatic reciprocating saw thingummy...my cuts are smoother, more accurate & SQUARE in comparison to theirs...lesson learned :-p
  5. #115
    Hi guys
    Had a look @ that model, are you cutting steel with the TCT blade or using an abrasive disc ?
  6. Quote Originally Posted by mekanik View Post
    Hi guys
    I've actually got the 255mm Rage 3 - just using the stock multipurpose blade that came with it.
    I use that blade for most rough jobs & have a decent quality wood blade for more important diy jobs.
    I've used it to cut wood, plastic, aluminium & steel - does a decent job on all of them.
    There's a video on youtube of a guy in the USA demoing it cutting through loads of different materials & comments on cutting finish & material temperatures etc Its worth a look if you're considering getting one.
  7. The Following User Says Thank You to CraftyGeek For This Useful Post:
  8. Click image for larger version.
ID:	10403Click image for larger version.
ID:	10404Click image for larger version.
ID:	10405Click image for larger version.
    Slow but steady progress - grabbing an hour here and there...
  9. Click image for larger version.
ID:	10621Click image for larger version.
ID:	10622Click image for larger version.
    First parts drilled, tapped (and fit!) decided to weld plates to the inside of the box sections to increase thickness for tapping... Thanks Jazz for the idea
  10. A word of advice to anyone buying a tap wrench - don't buy a cheap eBay jobby like I did - they are crap. Just ordered the real deal from starrett... :) same applies with centre punches - buy a starrett you won't regret it!
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
